BG BMW ФОРУМ
http://www.bgbmw.com/
BMW E63 M6
http://www.bgbmw.com/viewtopic.php?f=46&t=172
Автор:  Devil [ 19 Яну 2009, 04:20 ]
Заглавие:  BMW E63 M6
E63-M6
ИзображениеИзображение ==> S85B50
General
Make______________BMW
Model_____________ 2005 E63 M6
Powertrain Layout___ Front Engine / RWD
Base Price__________Not Available
Dimensions
WheelBase_________2781 mm / 109.5 in
Length____________ 4871 mm / 191.8 in
Height_____________1377 mm / 54.2 in
Width_____________ 1855 mm / 73.0 in
Weight____________ 1710 kg / 3770 lbs
Front / Rear Track____F 1567 mm / 61.7 in
__________________R 1584 mm / 62.4 in
Engine
Configuration_______5.0 Liter bi-VANOS V10
Valvetrain_________ DOHC 4 Valves / Cylinder
Displacement_______4999 cc / 305.0 cu in
Power_____________378.1 kW / 507.0 bhp at 7750 rpm
Torque____________ 520.0 Nm / 383.5 ft lbs at 6100 rpm
Bore______________ 92.0 mm / 3.62 in
Stroke____________ 75.2 mm / 2.96 in
Compression Ratio__ 12.0:1
BHP / Liter_________101.42 bhp
Redline____________8250rpm
Transmission
Type______________7 Speed Sequential Manual Gearbox
1st Gear Ratio______3.985:1
2nd Gear Ratio_____ 2.652:1
3rd Gear Ratio______1.806:1
4td Gear Ratio______1.392:1
5th Gear Ratio______1.159:1
6th Gear Ratio______1:1
7th Gear Ratio______0.833:1
Chassis & Body
Steering___________Rack & Pinion w/ Power Assist
Tire Sizes__________F 255/40ZR-19
_________________ R 285/35ZR-19
Brake Types_______ Vented Discs
Brake Size ________ F 348 mm / 13.7 in
_________________ R 345 mm / 13.6 in
Available ABS______ Yes
Body Material______ Aluminum and Steel
Performance
Top Speed _________250.0 kph / 155.3 mph
0 - 30 mph_________Not Available
0 - 60 mph_________4.6 seconds
0 - 100 mph________Not Available
0 - 1/4 mile________ Not Available
Lateral Acceleration__Not Available
EPA City / Hwy______Not Available
http://www.phpbb.com/
